Group: DynoMotion Message: 7722 From: tig415 Date: 6/20/2013
Subject: Mach3 and PWM spindle speed control
Hi
I'm planning on using a CNC4PC C41 - PWM Variable Speed Control Board to control my VFD. It is a step and direction unit with step as the speed and direction for CW and CCW.
After much searching it looks like "SpindleMach3JogsSteveRev2.c" is the best spindle program to use.
Am I on the right track or have I found another rabbit hole :)
Derek
Group: DynoMotion Message: 7723 From: Tom Kerekes Date: 6/20/2013
Subject: Re: Mach3 and PWM spindle speed control
Hi Derek,
If it was a Step and Direction device than I think that would be a good choice.
You didn't include any Link but I Googled and found this:
http://cnc4pc.com/Tech_Docs/C41R2_USER_MANUAL.pdf
From this it appears the C41 is not a Step and direction but rather a PWM and Direction.
PWM and Step Pulses are quite different.  Step pulses are usually fixed pulse time with a varying frequency (and typically never go beyond a low percentage duty cycle).  PWM is a fixed frequency with a varying pulse width (usually over the full 0-100% duty cycle).
There is a SpindleMach3PWM.c example that is probably more appropriate.
Group: DynoMotion Message: 7724 From: tig415 Date: 6/20/2013
Thanks tom
I'll give it a try.
> Hi Derek,
> From: tig415 <tig416@...>
> Sent: Thursday, June 20, 2013 4:23 PM
> Subject: [DynoMotion] Mach3 and PWM spindle speed control
> Hi
> Derek
Group: DynoMotion Message: 7818 From: tig415 Date: 6/29/2013
Hi Tom
Finally had some time to look at (and absorb) SpindleMach3PWM.c . I don't think that's going to work as it seems to specify a pin for for CW and a pin for CCW. The unit I have
uses the direction signal to change the relays. There are only 3 input terminals. PWM, DIR, ground.
The manual says:
 Inputs a PWM signal and outputs an analog 0-10VDC.
 Uses only two pins, one for PWM and one for direction. It is the presence of absence of
the valid PWM signal what would start/stop the spindle.
 Has two relays that can be used to control the direction and enable and disable the drive.
And
Go to Config / Ports&Pins / Motor Outputs. Enable the spindle and select the port and pins you wired for step and direction.
Go to Config / Ports&Pins / Spindle Setup. In the motor control box, check Use Spindle Motor Output and Step /Dir Motor. Under Pulley Ratios set the pulley ratios of the machine.
Derek
> Hi Derek,
> Hi
> Derek
Group: DynoMotion Message: 7835 From: tig415 Date: 7/2/2013
Bump
Hi Tom
The unit I have
The manual says:
disable the drive.
And
Derek
> > Hi Derek,
> > From: tig415 <tig416@>
> > Hi
> > Derek
Group: DynoMotion Message: 7839 From: Tom Kerekes Date: 7/2/2013
Hi Derek,
Sorry I somehow missed this.
But it seems like SpindleMach3PWM.c should work.   You are correct it is written to activate two outputs one for CW and one for CCW.  But I believe you can just delete (or not use) one of them and treat the other as a Direction.
Ah but I just realized we should probably not turn off the "direction" when we are told to stop and rather set the PWM to zero.
I've attached a modified program with Bit 26 as the PWM and bit 27 as Direction
